windscreen washers prob help needed mot tomorrow
wipers work no prob so its not a fuse as they share same fuse
was thinking stalk but the other positions are working
dont have another pump to test
all other electrics are fine
help
thanks
mark
have you tried the connection between the stalk and the steering wheel ?sometimes the copper connecting strip gets bent and doesn't make contact, pull stalk into washer on position and try to see if it's touching. good chance that is the problem.
Mk1 2l TSR G60.  .getting. There twice as fast
Try testing the pump across the batteryto exclude all other factors.
If it buzzes it's in the wiring - if nothing then it's yer pump
A starting point for you :)
