Whats this??????????? and where can i get a new one from!??
(In Topic #76969)
when the engine warms up it will start hestiating, done the usual checks and have bascially run out of ideas!
could anyone tell me what this is and where i could get a new one from, to see whether if changing it helps me.
its at the back right hand side of the engine bay, behind the same bulkhead as the wiper motor and heater fan.
it seems to have a heat sink on it and is wired to the coil?
heres a wider view!
and just for good luck, heres my actual car!!!! 8)
if anyone can help then i would be in their debt
John 8)
1983 mk1 gti 2.0l 2e powered
newman cam
ported, polished, big valve 1.8 head
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
I think lots of 80s VWs use the same part so try looking in a scrap yard.
This would be for engine codes HT, RD, PL and 9A
I don't reckon yours will have one. So it might be the cold start valve leaking and squirting more petrol than is necessary in, or leaking injectors doing the same thing.
You could try disconnecting the valve (by unplugging the sensor from the coolant outflow pipe on the cylinder head).
See;
http://volkswagen.msk.ru/vw_doc/eva2/FU01/ch6.2.html
Hope this helps
Ali Cabrio
Mars Red 1.8 GTi Cabrio 1985
Seat Covers
Scratches
Leaky roof
1 million smiles per hour
Seat Covers
Scratches
Leaky roof
TT
do you think that it could cause the symptons of my problem if it was playing up?
i always thought the cold start vavle only opereated on starting? (please correct me if im wrong)
the problem only occurs when the engine is warm and im driving, ie, if im stopped on the spot, it will rev away happily to its hearts content,but as soon as i pull away it will hesitate and miss. its not back firing or popping, so that says to me that its not fuelling, but obviously im not sure and more than likely to be wrong!
John
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
If it idles ok then hesistates under load it could be week mixture or poor timing.
Just a few idea for you, Good luck
Rob
Audi A4 1.9TDI - Gone
yea
The topic is electrical thingy!!!!
:roll:
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
www.maplin.co.uk
It's not expensive.
Ali
Seat Covers
Scratches
Leaky roof
Seat Covers
Scratches
Leaky roof
here we go. Ive now found the problem! and my car is running sweet again!
i was running out of ideas fast, so just out of interest i swaped over the rotor arm and hey presto, shes cured!
im hearing you guys say, "well why didnt you check that first!" well i only replaced the rotor arm about 2 months ago as part of a service i carried out on my car! so i put the old one back in. on closer inspection of the dodgey rotor arm it looked as if the striking plate was slightly off horizontal and perhaps not striking the contacts on the inside of the dizzy cap properly?
its all good though, cos it was a free fix! and we were on the brink of giving up and taking her to the garage!
Thanks for all your input guys.
Sorry i didnt get back to you scouse. every spare moment ive had has been in the engine bay of my car!!!!
you should put up a list of your stock of parts dude.
John
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
Life Member
I put up with the symptoms for 3 years and once the leads were swapped the hesitation stopped straight away.
Dan
Life Member
Dan
