What is this and why is it not plugged in?
(In Topic #143013)
They wire in from here
I know it's a bit vague but seems odd for them to be hanging and I can't see anywhere obvious to plug into.
Hopefully you can see the part number here 171 972 509
1985 Mk1 GTi Cabrio
1954 2332cc Oval Beetle
1965 Notchback
1966 Split Screen Devon Camper
2005 V6 Touareg
1965 Notchback
2005 V6 Touareg
As to why it isn`t plugged in ? Maybe had a new clutch and fitter forgot, or maybe prob with rev light or dash clocks :dontknow:
Hope that helps Sean
CAMPAIGN-HELIOS BLUE-POSSIBLY SEEN IT ON CHRIS BARRIES(RIMMER IN RED DWARF) MASSIVE SPEED PROGRAMME?!!!
Mark
1985 Mk1 GTi Cabrio
1965 Notchback
2005 V6 Touareg
1965 Notchback
2005 V6 Touareg
rubjonny said
could be its had alter gearbox fitted weith only 2 pin plug for reverse switch. if so that plug will never go in and your big mpg gauge will always be dead
I think you may have the answer there. There is no connector that i can see, but i can see a 2 pin plug, and the reverse light is working. That said the gearbox is looking very leaky and there is definitely something not quite right with it, although it seems to be working fine. Think I might start to look for the correct box though and aim to replace it over the winter.
1985 Mk1 GTi Cabrio
1965 Notchback
2005 V6 Touareg
1965 Notchback
2005 V6 Touareg
