Water temp relay HELP for a caddy diesel with ABF conversion
(In Topic #142112)
I have got a caddy (diesel) with an ABF conversion and i am trying to understand how the water temp works, all i know so far is that it goes through a relay.
Does anyone have a wiring diagram?
Does anyone know what relay number it should be?
Can you bypass the relay?
HELP!!!!!
Jase
Can anyone help? I've been looking into it a bit more and i don't even know if i need a relay.
Does anyone know the wire colours from the MK3 loom to MK1 loom and have a wiring diagram?
Cheers Jase
the dash temp sender is the small single pin one in the side of the head, plug your mk1 red/yel wire to this and you're away
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=113764
The only thing is i've got a 2 Pin sensor on the side of the head. Does one side need to go to ground/positive and the other side to red/yellow wire?
Jase
you should have another black single pin sensor in the side of the head near the coolant flange. it must be there somewhere or at least some kind of sensor in the 2nd hole, otherwise you would have coolant pissing out the side
I have found the offending sensor, and it is connected to the red/yellow wire. But the temp gauge still doesn't work!! I have earthed the wire and the temp gauge works. Is the sensor faulty? Is there a way of testing if its working? Can you HELP?
Jase
if it still wont register anything then you'll need another sensor, if you have your old engine lying about you can pinch it off that, its exactly the same as the abf one
if not, any mk1 golf, early mk2 and any mk2/3 16v will have the sensor you need. if you buy new make sure it is genuine as pattern sensors are a bit pants
I have fitted a new temp sensor, and all is working well thanks. But the temp warning light is flashing constantly do you know if there is a way to stop it flashing or will i have to put up with it?
Jase
if not then its the wiring or the control relay #42/43 above the fusebox. if you bridge the red/blue to the brown on the back of the relay socket that should stop the flashing. if not try removing the relay completely, that should stop the flashing. coolant gauge will still work, just your level sensing system will be disabled.
