water temp gauge only... light fine
(In Topic #97296)
the light flashes when key turned on stays on for a few seconds then goes out…
i left it running for ten mins but didnt want to run it too long as i couldnt see temp as gauge didnt move..
also fan didnt kick in… but i may not have run it long enough for that..
its the ecu fuel injected sportline cabby on a 91 just for reference
any help greatly appreciated
Dene
ive replaced the sensor… nothing..
bridged the wires… nothing…
ran a live to fan.. that works..
but there is no live to fan or sensor, and fan isnt kicking in..
HELP!!!!
Temp guage , pull wire off sender put some resistance in the wire , eg a 12v bulb or you will blow the guage and with ignition on earth the sender wire .
Guage should go to full ? If not guage or wiring is faulty , is fuel guage okay ? It shares the same voltage stabilizer .
that the little black three prong thing on the back of the clocks?
any advice on sorting this?
many thanks for your reply mate..
Yes mate
Voltage stabilizer .
If both temp and fuel gauges don't work it is often a sign of a broken voltage stabilizer on the back of the clocks that supplies a constant 10V to them. Check the supply from it (3 pronged transistor held down with a screw) with a mutlimeter. If it is broken new ones can be bought from GSF or VW.
