Washers not working
(In Topic #131103)
Washers not working
The link below shows pictures of 'my wife's' Mk1 Clipper Mabel which I bought her for Christmas
Photo and Video Storage | Photobucket
The washers haven't worked since we got the car so I have had a look and need some help.
With the ignition on or engine running the wipers work correctly moving the stalk up and down but if the stalk is pulled back there is no washers the pump does not run. I have checked the continuity of the wiring from the multiplug on the column (green and brown wire). All good and the earth at the pump end is good.
There is 11 volts coming through at the pump multiplug when the stalk is pulled and the wipers sweep the screen as they should however if the pump is plugged in there is nothing
Can anyone shed any light on this problem??? I need to get this sorted quickly as we are taking the car to Brugges next Friday and don't fancy driving in this weather with no wipers 8O
Can you not feed it with a direct 12v feed just to check?
1988 1.8 carb Golf Clipper
if you take the plug off the pump, bottle end and connect to the new pump, just dry outside the bottle as a test does that work when you pull on the lever? ie make a nice wirring noise.
if not and you still get a good voltage at that end of the cable only when you pull the lever back could be the connectors in the bottle end plug are corroded or simply not make a connection??
and you are measuring for a voltage across the two pins at the pump end plug I presume.
I'll measure the voltage with the pump plugged in. I have tried to get some wiring diagrams but not having a lot of luck at the moment. Cant seem to track down a Haynes manual either :cry:
As I need the car for the weekend trip to Bruges I have had to wire in a separate switch so that I at least have washers.
Managed to find a Haynes manual on eBay so should have that this week at some point which will give me the wiring diagrams and I can hopefully sort this out and get them working as they should :roll:
I'll update if and when I get this done
If you can read this, thank a teacher,
If its in English, thank a soldier.
A soldier fights not because he hates whats in front of him, but because he loves whats behind him.
Something is dropping the voltage when the wipers AND the pump are triggered. my pump works and if I disconnect it the wipers work but together nothing … The only thing I have found is a little corrosion on the fuse panel plug (yellow one from memory), tried to clean it, tightened the pins as much as I could, plugged it all back and got a wipe & a bit of liquid and then nothing … unplug the pump and the wipers (the pull forward swipe) work again …
14D & 17CY
to confirm if its a stalk issue, jump the red/green wire with 12v at the stalk end
