Vw Golf mk1 gti 1979 donīt work....HELP
(In Topic #135239)
I need your help if itīs possible.
I recently finished my 1979 Golf 1.6 GTI and the worked fine untill one day that is shut off and didnīt started again.
I measured all things and I donīt understand the cause of this malfuction.
I think the ignition switch is causing this problem but my only doubt is that I have starter…so I donīt know if the ignition switch is bad or not…
I checked the fuel pump relay in other car and itīs ok but in my car doesnīt work..
I made a jumper to the fuel pump and works fine…
The coil dontīs have spark or 12V at the crank…I tested the coil and thatīs ok
My car doesnīt have ignition module..
Can you help me please???
Re: Vw Golf mk1 gti 1979 donīt work....HELP
gti16v said
donīs
What is this word?
If the word is "doesn't" then it sounds like your ignition switch, or some of the associated wiring or connectors, is faulty.
paul_c said
gti16v said
donīs
What is this word?
Hi,
thanks for your answer, I really think thatīs the ignition switch who cause the problem but the fact that the starter workīs at the crank confuse me…..
Thereīs any way to make a test to check the ignition switch??
regards
The fact that there's no power at the coil is the main issue though, its just the finding out which connector or wire (or the switch) is broken.
The problem was in the breaking points….thanks for you help..
