Voltage drop
(In Topic #116146)
Voltage drop
I noticed the other day if I try the horn before the battery light goes out, all I hear is the relay clicking and not the actual horn, but as soon as the battery light goes out, the horn works????
can any help?
1982 Non Sunroof Black 1600 GTI
2003 MKIV Golf PD150 GT TDI
G60
Don't think it is a voltage drop problem it is the same wiring from battery to horn circuit with engine running or not.
Keep smiling J.
Beetle restoration. Cabrio GTi (black and shiny). Golf driver.
16v MK2. (Oak green) Now on a Clipper (to keep). Audi A8 4.2 Quattro sport and a BMW R65 bike.
as i say, mine are the same. i know my battery is healthy as i have checked it, just my horns need the engine to be running for them to sound. I just havent bothered to look into it, since they work fine and I have other problems that are more pressing
When i first got the golf and went to fit the air horns i had lying around, they wouldn't work. the pump span but no noise. direct on the battery they worked!!!
I checked the voltage at the horn cables and with the button pushed (engine off) i had 11.8v. engine on i had 12.4. Battery read 12.7 stood still!!!
i had a massive voltage drop across the loom, so i fitted a relay and the horns are fine now!!! I'm guessing they needed 12.7ish to run but weren't getting enough.
My mate had the same problem in her jetta. Relay cured it.
Jon.
~Madferret
Mk1 1457cc 5door GX '83
Madferret said
relay will cure it but it's not neccersery, the problem is old wiring, which can (and should) be replaced as fire and cars dont mix well.
how do i fix this then without fitting a relay :dontknow:
i thought that i'd only need to replace a wire if its actually damaged (i'm yet to do a continuity test but will let you know)
can it be that all related terminals and earths are brushed clean and maybe cure it that way???… without replacing the wire?
~Madferret
