very strange things
(In Topic #120208)
very strange things
i think they are all related so will list them
rev counter does not go above 1500 and stops totally when lights/dimmer is on
when lights are switched on mfa goes totally dim
can turn ignition on(not engine)with headlight switch
this issues also affect oil warning light
reverse lights dont work
clocks? fuse box was changed? help!!!!
any ideas as i plan to investigate at the weekend
thanks
simon
Also I think the MFA earths with a strap on the carb, from what other people have mentioned.
~Madferret
Mk1 1457cc 5door GX '83
reverse lights could be the switch is not pushed onto the gearbox correctly or the wire has snapped at the rear plugs? are your brake lights coming on ok?
had run ignition feed onto clocks which was interfering and earth pin was missing
new clocks and a bit of remodifying then hopefully be all sorted
thanks for advice!
si
had pulled feeds off plug to clocks and soldered directy onto board…
just got to get clocks now then figure out how easy it is to remove speedo head as i dont want to lose mileage
