VDO Senders Again!
(In Topic #117583)
VDO Senders Again!
I have taken the lighting circuit from the cigar lighter and all works fine and they dim.
I have wired the voltmeter to direct to the battery and it works fine.
I have replaced the oil pressure sensor in the front of the oil filter housing with an Audi unit and that guage works OK.
No which one is the temp sender for the MFA, is it the one at the back of the oil filter housing or is it the one on the end of the head on the right hand side as you look at the engine.
I understand that I need a new sender as the Audi gauges are different to the MFA……where would I get one of these blue senders?
Also my MFA has stopped working since disconnecting and reconnecting the wires on these 2 senders
Help would be appreciated.
Part number is 049919563B
G
