VDO guage problem
(In Topic #131910)
VDO guage problem
What you need to do is look at the fuseboard FAQ in the atrchives and work out what wire you can tap into for a switched live.
Ill give you a clue, its black and goes from pin 15 on the ignition switch
VDO
It should be possible to find an ignition live after a bit of searching with a, ummmm, voltmeter.
