With work and life commitments i can be a little slow to get round to things. Any way on top of the filter head is the temp oil sender nearer the front of the car Further to the back the oil filter head is the oil pressure switch. The double pole Audi switch was too big to be screwed in as a direct replacement for the original Oil pressure switch( not the thread, just the senser) So i've switched the oil temp and pressure around on the oil filter head. Is this going to make any difference. I'm assuming the T piece was only if you wanted mfa to work as well as vdo gauges(Car doesn't have mfa) I've got time on sat to mess around making electrical connections. Just wanted to make sure I wasn't wasting my time as the temp switch and pressure switch had to be in the original positions. Some my questions may seem a bit simple to you experienced folk, but I'm just starting to get my hands dirty. Enjoying the experience so far.
