VDO gauge bulb FITTINGS/holders - Where to buy?
(In Topic #85684)
i think its a push in then turn like 90degrees or something?
then it will have a - & + on it to light the bulb.
they are fairly long anyone know the part number or who sells them?
Ring for catalouge
Cheers…………
here you go perfect example
the black bit in the back of the gauge.
if not i might get some LEDS bright white 12v ones with wires and try and make them stay in somehow.
any ideas
Well these are the lamps for the Audi VDO dials that i am using!
I work for an electrical wholesaler and spent a whole day finding a lamp company that sold them, after i finally found a company was told that he would only sell me them if i took all 50 off him as they'd been on his shelf for about 5 years. Total cost 42p a lamp!
Lamp details:
12v 1.2w Wedge Base Mini Capless Lamp.
Maplin electronics sell them for ?2 a lamp ( but every time i tried they had none in stock):
http://www.maplin.co.uk/Module.aspx?ModuleNo=47447&doy=13m3&C=SEO&U=strat15
Or i found these that are well priced (for retail) (?2.65 for 2 lamps or 10 lamps for ?5.85) and are 100 % correct:
http://www.consumabulbs.com/files/bdet.php?id=63
or if you want give me ?1.50 to cover the cost of 3 lamps (thats if you want 3) and a stamp i will stick some in the post for ya!
PM me if you want some!
My car has already had my blood sweat and tears and now is trying to take over my soul!
Well yes i think ill have to PM you when i get out of work and have a chat as i need a few of these.
oh by the way i need the holders more than the bulb.
the fitting shown in the pic.
i do the lamps/bulbs/leds in where i work, we stock all the same sort of things maplins do, as we were out 1st specialising in components for over 25 years so i got all the bits.
except the VDO bits.
i just want it to fit withought worrying having to make holders.
hope you can still help.
anyone know why my black bit keeps falling out. I know you insert it and twist it 90 degrees, any other advice to get them to stay?
i cnat find any other threads about this on the internet so this might be useful to people
de3660 said
or does anyone know the part number of the black bit??
dont know it, but will try and have a look when mine falls out the VDO again. :roll:
anyway that would be GREAT, then i can get somewhere once i know the part number of it.
thankyou
will check for part number and pop one up. dont think it will have one on it though.
sorry
it should do if its a proper VDO part, ive seen them on the net but not clear enough to see letters and numbers.
what timing, feel sorry for you thought, id glue it in to be honest drops of glue then when bulb needed replacing, rip it off, it wont go that many times.
my gauges are VDO, but that part might not be. :?
good luck anyway!
Guest user
They are still avlaible direct from the dealership under part number: 437 919 039 "socket for bulb"
AndyCEB said
If your coming to the pod I have 2 brand new ones you can have :wink:
I asked in VW the other day and they said they didnt have them? :dontknow:
Guest user
Guest user
Went in Monday morning and they had them for me to collect Tuesday afternoon, as I was fitting larger LEDs I tried to modify one of the holders to work but knackered it in the process ops: So didnt use the other two, hence having two spare now
de3660 if you want them drop me a PM with your address :wink:
