undoing the starter motor bolts - what bit size?
(In Topic #105117)
Hi all, have traced a fault to the starter / starter solenoid - can anyone confirm the size of the bit drive needed to remove the mounting bolts? I've tried T50 torx but it looks like this is too small, however a T55 wont go in! also 8mm allen key is too small
I've already slipped once with a T50 so the bit is slightly rounded in one bolt - i dont want to make it worse by using the wrong bit!
Any help greatly appreciated!
Chris
Chris
From memory it's an allen headed bolt, not a torx. If you've dounded it get a larger spline tool and hammer it in tight and then undo it.
starter
Cheers, I'll take a look tomorrow and give that a go
thanks
Chris
thanks
Chris
Just bought two new bolts, it should be a 7mm allen head. I don't think you get this in a regular set. Just like the 18mm socket is never in a kit.
See my post in" big block injection engines". Just been through all this along with a real disaster, had to cut the heads off so take care. J
Beetle restoration. Cabrio GTi (black and shiny). Golf driver.
16v MK2. (Oak green) Now on a Clipper (to keep). Audi A8 4.2 Quattro sport and a BMW R65 bike.
