this'll get ya thinkin?????
(In Topic #77041)
just got the dash back in and fitted the wires to the light up gearnob (its not as bad as it sounds ops: )and when i switch the lights on its all ok but occasionally when i switch it back to side lights the fuel pump energises :? 8O ,like it does when you switch on the ignition
any ideas :dontknow:
d
Birmingham
Basically eletricity will find the easy way to earth, ie least resistance. Pauls suggestion is spot on, basicaly the relaiy is enegised then the power from your iluminated gear knob is using that circuit as an earth and holding the fuel pump on!
If you disconnect the gear knob does everthing work correctly?
Rob
Audi A4 1.9TDI - Gone
