they keep flashing!
(In Topic #89684)
they keep flashing!
so calling all people witht he knowledge, please help!
when the headlights are on with the indicators the headlights will dim with the indicators, and the indicators are very dim to start with…
Cud anyone think of why this is?!
Thanks in advance.
Nick.
List from dubboy !! You need to look at all lighting one's .
Rosette LH side behind headlamp (LH lights, front washer)
Rosette RH side behind headlamp (RH lights)
Strap from alternator to engine block
Strap to rocker cover (82> models only?)
Earth wire from diagnostic terminal block to battery (>76 models only)
Earth cable from battery to body
Earth strap gearbox LH mount to body
Earth wire from steering rack bracket to body (for horn)
Rosette on back of instrument panel
Rosette on bulkhead near fuse box / steering column bracket
LH front door contact switch (self earthing)
RH front door contact switch (self earthing)
LH rear door contact switch (self earthing, 4-door models)
RH rear door contact switch (self earthing, 4-door models)
Earth wire to interior light bracket
Earth wires to body floor (under rear carpet near bench seat for fuel pump and fuel tank sender)
Earth wire near LH tailgate hinge behind headlining (rear wiper motor)
Earth wire near RH tailgate hinge behind headlining (heated rear window)
Earth wire to rear tailgate slam panel LH side (LH rear lights, number plate lights)
Earth wire to rear tailgate slam panel RH side (RH rear lights, rear washer)
it comes on intermittently for varied lenghts of time
i know the oil pressure is fine as i got a VDO pressure gauge
and have changed the senders
i saw somewhere that there is a earth wire in the dash that is used on the oil light and buzzer
any help on its location, colour and will i have to take the whole dash out to sort this
cheers Ash
1982 Non Sunroof Black 1600 GTI
2003 MKIV Golf PD150 GT TDI
2 seconds after 2000 RPM or more, light and buzzer come on, replace the high pressure switch.
Oil warning light on at idle, especially when hot, replace the low pressure switch.
No oil light blinking with key on, engine off, replace low pressure switch and/or repair light in instrument cluster.
So its check / replace senders , check wiring connections if all okay and checked with suitable oil pressure guage it means clocks have an internal fault .
See also http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=40065&highlight=buzzer
and
The Mk1 Golf Owners Club
