Temp gauge
(In Topic #118238)
Temp gauge
still seem to work just starts in i way too high position. i tried another gauge, same result. coul the sender be at fault.
its a 1.6d with a 1.6td fitted
mark
whichever has the red/yellow wire on right now is what the gauge is using
did it have a level sensor? if so try pulling out relay #42 or 43, will be clipped above the fusebox.
~Madferret
Mk1 1457cc 5door GX '83
~Madferret
Try the inside the dash/clocks and see if theres a short somewhere, you could possibly try removing the pin out of the plug on the back of the dash and see if it still shows 3/4, unless RubJ can suggest a better way? :wink:
~Madferret
