Temp Gauge & Fuel Gauge Help
(In Topic #159428)
Do check the earth wire that comes from rocker cover to the coil mouthing bracket bolt, also the brown white wire, which I believe goes to earth via the fusebox.
I tried a new temp gauge sender etc and all the other recommend fixes.
My solution was to take the clocks out and clean the copper contacts on the blue Mylar circuit board. Gentley does it. Then wrap a couple of turns of leccy tape over the nib the contact but folds over. This made for a tighter fit when the loom connector was reattached making better contact. Never had a problem since.
chortle said
I had a dodgy temp gauge etc, flashing light etc
Hi Thanks for that, i just checked the earths which are ok and also did the mod on the clocks as you stated, no difference im afraid but i did notice when the fan comes on it only stays on for 20seconds, which is why i assume she is still creeping up in temp. surely it should stay on longer? also only takes about 3 mins on idle to get up to 3/4 on the temp gauge is that normal?
Does the red light flash or is it just the temp gauge needle going up? Mine sits at 3/4 sometimes. Check the return pipe to the expansion tank has a good flow of coolant back to it. I t may be worth taking the rad hoses off and flushing the entire system out with the hose pipe to make sure there's no crud in the system too.
Then refill with recommended mix of coolant and water.
Could also be a faulty thermostat, not opening fully to let the coolant run around.
It should not be getting that hot in such a short time, there is something wrong somewhere…..
mark1gls said
There is an air lock that you have missed, does the heater blow hot air and did you set it to hot when you drained and topped up the coolant. Feel the hoses to make sure they get hot, the last one to get hot should be the bottom radiator hose as only flows throught when the thermostate is open.
Hi i fitted a new thermostat & temp sensor yesterday and refilled system making sure no air blocks including the heater, and all pipes are getting hot. But she is still going high on the gauge. does anyone know what the normal running temp is?, as i might try and check this, to decide if its really faulty or she is getting very hot. Really tempted to light a match under the car yesterday
i replaced the printed circuit on the back of the dash cluster and it made no difference, when the fuel injection was set up incorrect and it was running way too rich the guage shot over ! now its all set up correct it just creeps up and over to top in about 4 mins, if i continue to drive it eventually as the engine actually warms up it pushes the gauge even further and the light starts to flash.
As for your fan only coming on for 20secs, thats controlled by the thermo switch in the rad so it may only need that long as the engine isnt actually that hot
if you do something that makes the guage behave please please post what you did, there are literally hundreds of posts online about rising gauges that are donkeys years old but none of them have a solution !
