temp and MFA problems
(In Topic #73087)
nick
Problems with MFA and clocks can be difficult to fix - MFA will probably mean new clocks - But can be a s simple as the fuse being gone
I'd be wary about temp gauge not working - make sure the engine is not running over hot and that the cooling fan cuts in.
EW does not signify a Campaign but it is one of the features - read the Campaign Checks on the left of the screen to do the Identification properly.
Make sure it is not a 1.1 or 1.5 that has be campaigned!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=4537162416&ssPageName=STRK:MEWA:IT
again..any advice would be very welcome…had no idea it would be so hard to get (a straight)one of these!
thanks
check the fit of the panels - gaps should be even
Check how the door fits in the body over the top of the windows - the seals should be nice and flush in the body - look at the corner at the top of the a post - any gap between seal and the underside of the roof/door shut suspect a front knock
Check for barcode on central front panel support, on driver's b post and for the sticker on the inside of the rear panel. missing any of these may indicate repainting/new panels
Read the Buying a GTi guide on the left of the screen.
Rich
If it is - and you take a look at it - double chech the top of the inner wings. If that 'black stuff' is rust then walk away!
