tailgate solenoid recommendations anyone
(In Topic #148777)
______________________
1983 Lhasa Green Golf GTI
The solenoid itself looks no better than the average one you get on ebay for sub £20 (jom type), but I'm sure the lock itself has been modded a bit - will get a cuppa pics up for you over weekend if u can wait bud.
For some reason, the boot takes a good slam to close once open - not sure why as rubbers have been adjusted like…wondering if this has anything to do with the lock itself, (will try good greasing as musta been a while), but as long as it stays shut not a biggie at moe. List as long as me arm of other fixes!
Mk1'83 G60
Mk1'82 2.0L 8v
Mk1'93 GTI Sportline
Mk1'82 2.0L 8v
Johnny - the rubber buffers (circle rubber stops either side of tailgate?) are missing from my tailgate. Prob coz I replaced the tailgate in the restoration. So on that note it should be easier to lift open without these? Not sure if i'm reading this right….
Jinsta - thanks. i've greased the lock thru but still no joy. The mod to the lock sounds interesting and am keen to know more if there is a mod. The lock mechanism is so hard that the solenoid can't trigger it open even when the tailgate is up/open. I was thinking of anew lock but speaking to Crazy Quiff this morning he said there isn't really anything to the lock and nothing that abit of greasing shouldn't sort.
Weekend is fine for pics, much appreciated.
Dean
lock from inside with washer piece welded on…
sol unit in place fitted. the puller/cable end to left
complete unit. its grounded on itself as above shot and fixed to through tailgate via two spire clips
cable end looped and held with little clamp
In terms of sol kit make, its a 'Directed Electronics 522T' and all the bits on the completed pic are std pieces inc with kit (bar the little clamp) - got jammy with mine as found one for £10 on ebay in dec. terms of boot shutting...still have slam it, tried adjusting lock/catch but just made it worst
hope u got yours sorted in end
Mk1'83 G60
Mk1'82 2.0L 8v
Mk1'82 2.0L 8v
