stuck! no sound from my speakers
(In Topic #149711)
i did a quick test on a new head unit (which i know to be working) and i cant get any sound out of the speakers but the head unit does power on and seems to function normally apart from this.
i think the fuse is ok as it still powers on, just in case i tried another head unit as well, same problem.
any suggestions?
http://en.wikipedia.org/wiki/File:ISO_10487_connector_pinout.svg
1.5 Mk1 Golf GX
i have connected some speakers to it, but still nothing, also tried to run it through an amp (which i also know to work) and through some other 6x9 speakers - nothing, not even a buzz
Assuming that the cables do connect directly into the speakers (i.e. no amps or crossovers) then you should expect to see a low ohmic reading. Only the pairs will give a reading, all others will be fully 'open circuit' or high impedance. Your speakers will be 4ohms each, but don't consider this to be the DC ohm reading. You can use a simple continuity meter type also, but be sure not to put 12V down the speakers, these things work on millivolts.
Ceck the head unit also, turn it on, put the radio/CD on and turn it up. Prove with a spare speaker it works then if so, concentrate on the cabling between brown plug (or what's left of it) and the speaker itself. If there has been an amp in previously there is a chance that the cabling was used, but connected direct to AMP. If all that fails then check you have a low resistance continuity across the speaker terminals.
The above is not the solution, but a systematic means of fault finding. The cabling is not difficult, just direct pair of wires between the head unit and the speaker. The thing that screws it up is someone else tamperfering before you get there.
Hope this helps.
really confused now i'm on the verge of starting again with all the wiring for my head unit, but i'd rather not as it will be a pain in the bum
also i'm less than useless with one of those deeleys for checking ohms etc so i would need a fairly decent explanation of how to turn it on before i think about using it
Use the brown wire on the multiplug as your earth reference on both vehicles. The little plugs do come out of the multi connector pretty easy, use a very small flat screwdriver, it's 'spring' loaded and this just needs a push deeper into the connector, slip the small screwdriver into the rear and the connector will simply slip out from the rear, then push into the new position. This should get your unit working in the Mk1 as per your Polo.
It's a five minute task once you get around the need to switch your live pins in the multi connector. If you fancy a drive to Glasgow I'll do it for you. :-)
Free Car Alarm, Remote Start, and Car Stereo Wiring
i'll have a go when i'm next out with the car and report back!
