Strange Problems, nothing works...
(In Topic #119519)
hi had a strange problem today.
all things are ok, 5 minutes later my fuel pump stops to run and everything stops running well.
when i turn on the lights the fuel pump make a strange noise.
when i turn on the horn the some thing.
the turn lights doesn´t work either.
is this a problem with the fuel pump???
help me please
a mate of mine had this in a mk3. was dead for an age then it worked, then it didn't, then it did etc. til i put a dif relay in and robert is your mothers brother!!!!
Jon.
ops:
Jon.
~Madferret
Mk1 1457cc 5door GX '83
my question is if the fuel pump is damaged it could send the positive in all system and explains why nothing work, is that possible??
gti16v said
hi,
na , it would blow the fuse
have you tried the earth from battery to the body , you could quickly test this by using a heavy duty jump lead between the neg on the battery & the body work & then try maybe try a lead onto the engine from the neg of the battery
baz
~Madferret
cheers….
