Strange no start issue Wiring related and help needed
(In Topic #142849)
I have a very strange issue occuring. My 1983 GTI will not start, upon turning the key to on position two lights in the cluster blink, when trying to start the starter does nothing.
I have replaced, Battery (13volts), Starter and Ignition Switch. I have a also replaced to the large cable to the starter.
What I have found is the wire going to pin 50 on the starter has voltage 8-9volts while the ignition is on. This does not seem right as I would assume it should only have voltage while actually trying to start.
I need to check tomorrow but could there be a starter relay that has failed allowing the power to pass through which may also be making the cluster lights go crazy.
Any help more then appreciated.
Thank you.
Tyler
Mk1 golf gti
Mk1 golf gti project View topic: 1982 original Irish GTi - The Mk1 Golf Owners Club
mTDI corrado
Mk1 skoda octavia vrs combi
mTDI corrado
At the top is a fusebox diagram and lay out.
It's at the top, have a look there for info on starter relay etc.
On later ones there is an x over relay so that all power goes to starting the car.
I would doubly clean all the chassis connections inc the battery ones.
On old cables you can loose current.
to check starter run a wire from battery dirtect to pin 50 on starter, if it cranks battery and cabling is ok. now plug the red/black back in then disconnect ign switch plug and bridge the red to the red/black. if starter cranks then wiring is all fine, issue is the ignition switch. if not the red/black wire is at fault somewhere
Thank you Mr Johnny.
