Strange Headlight problem..
(In Topic #77200)
Anyone had this, is something wired wrong, or bad earth etc ?
Where are the earths on these cars '89 Clipper
Marc
Just make sure they are corrosion free and if you do have to cut and join wires that they are nice and watertight afterwards. Use some heatshrink tubing if you can. Solder the wires together if you can too.
Cheers,
Ross
Mike.
1983 White cabriolet GTi
Ross, I have checked the connections at the light end, and all looked clean and tight.
I will try bulb like Maniac says and if not then I will go back and look deeper into connections again.
I looked at the bulb and couldn't see any broken filaments, but I never knew that when on full beem the dipped beam turns off !
Marc
If its not fuse (will check tomorrow) then which of the three ires to the headlight is the full beam?
Marc
The pin for main beam is the terminal on the right hand side as you look at the back of the blub with the middle terminal at the top. The left is the common, and the top one is for dipped beam.
Mike.
