Sticking Starter Motor
(In Topic #72465)
Looking at the price lists the starter is unique to MK1 Diesels. Not sure if it is just a heavy duty version of the normal big block starter or whether it really is different.
Has anyone had any success rebuilding solenoids on starters or is it best just to get a reconditioned one?
Only problem I've had with starter motors is them NOT working at all. Sometimes this has been temporarily cured by a hefty "tap" with a soft headed mallet, but it usually means its time to get it reconditioned / replaced. How much are the diesel ones compared to the big block starters?
Cheers,
Chris
I think the problem now is the starter/solenoid itself though as the key does return to its normal position and presumably its trying to release the starter from the flywheel. :cry:
Depending on where you look the Diesel starter is slightly cheaper than the GTI version which is a nice surprise. Will try a few scrappys over the hols and still have to pull the old one out and have a look to see if anything obvious is wrong with it.
So much non-car stuff to do at this time of year and the GTIs in the (relatively!!!) warm dry garage, so working in drive. Glad the evenings are now getting longer and warmer. :wink:
