Starting from hot
(In Topic #76594)
Starting from hot
Cheers,
Mike.
Cheers,
Mike.
Cheers,
Mike.
andunp said
if the lights go dim as well its a battery related problem 8O losse cable or just knackerd battery :wink:
Yep, there is a bit of judgement too, though. You're looking for 8-9V whilst the car is being turned over and 12V or more while the ignition is on but not turned over. So, you're lights will dim but shouldn't go too dim, or out, whilst turning the starter motor.
Battery or its connections (they're not complicated - a thick wire directly to starter and an earth cable to gearbox mount is what you're checking) is the cause, it could be alternator as the root cause of the issue, though. Well worth getting a voltmeter and checking this out:
All electrics off , engine off: more than 12V
Spinning on starter: more than 8V
Just after starting: 13.5V or more
..which should gradually fall, to… : 12.5V approx
headlamps on, rear window demister, wipers, radio:
11.5V approx
Cheers for the help.
Mike.
Assuming yours isn't an auto, at least the Golf is nice and light (and no cat) so bump-starting it is dead easy.
