starter on caddy conversion
(In Topic #145751)
Hi, finally got ready to start aaz conversion for first time. Then…nothing. It has a new battery. Lead from positive at battery to starter, twin wire to alternator. I used the thick red/black wire as the trigger .
I have tested out of car and using a wire from positive to trigger and the starter engaged.
What could it be ? have I used the correct wire for trigger? or should the thick red/black go to positive pin on starter?
thanks Sean
thanks Sean
CAMPAIGN-HELIOS BLUE-POSSIBLY SEEN IT ON CHRIS BARRIES(RIMMER IN RED DWARF) MASSIVE SPEED PROGRAMME?!!!
The trigger wire will have a white connector on it and will be about 10 inches long that comes through the bulkhead with the loom on mine it is a thick red wire with a female connector on you will need to patch a lead from this to the starter.
The other lead will be permanently live when the ignition is on.
I might be talking dutch as this is how it is on my cabby.
How this helps
How this helps
1982 GOLF GL CABRIO WITH CLIPPER KIT ON BBS RA'S
1996 Toyota Starlet (Wifes )
2007 Focus Ghia TDCi
Starter wire should be red with a black trace. It goes to the spade terminal on the starter solenoid.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
Is this a manual or an auto?
If you want the PSD Boot Sticker file, it's here: Boot Sticker
Well I managed to get it started. I think it may have been a poor connection from the trigger wire to the spade on the motor.
put new connector on and alls well.
thanks for any advice given. very much appreciated :clap: :clap:
