starter motor problems
(In Topic #129462)
so i went round with a volt meter and when you turn the key i get 12v to solenoid and the is a 12v line going to main solenoid pin
so i tried to connect another 12v line from battery to the pin that get 12v when you turn key and it went but doesnt go when connected to the ignition pin 50 line
what could be going wrong?
bad earths?
across the battery there is 12.8v and same from main solenoid terminal
what next?
Does it click at all when trying to start it?
How did you repair it? I might give it a go tomorrow. I ran a direct earth from negative to gearbox housing and still no luck. Could it be that I'm using the 1.6D starter? Thanks.
thanks for all the suggestions
