sportline starting problem ?
(In Topic #96823)
hi ive got a bit of a problem with my car you go to start it and its fine then later and nothing on the key ignition lights are on though then when i put jump leads on to the battery it fires up no problem . any ideas could it be the ignition switch ? any help would be appreciated
What do you mean "put jump leads on the battery" - do you mean jump starting from another car?
yeah mate jumping from another car
ok sounds like a duff battery then. Do a voltage test on it while its trying to start the car. Should be around 8-9 volts across its terminals minimum.
Sounds like you need a battery or at least to test your charging circuit
ill try that then i thought it might be a dodgy battery cheers mate
