Speedo/ mileometer problems.
(In Topic #124033)
I have a 89 clipper and the problem is the speedo works fine however the mileometer and trip only seem to work infrequently, once a day max and usually first drive of the day.
Any ideas please. Thanks
Apparently the little cogs can wear out, its a case of stripping it internally and fiddling around like a Swiss watch, I think. Or, fitting another (and carefully adjusting the reading to reflect the car's actual mileage, of course).
if so how do you know which one to buy and where can you get them from?
ive got a 1457cc gx 1983 manual box.
hope someone can help!
martyn.
golf_gx_1983 said
is it just a case of replacing the drive cog on the gear box??
No
If the speedo is working but the mileometer isn't, then its internal to the speedo and nothing to do with the gearbox or cable.
