speedo help
(In Topic #72881)
speedo help
When it gets up to about 80 it wobbles/vibrates as much as 7 mph. My rev counter is totally steady 4k no wobble.....any ideas?
I remember posting this before for someone on the old forum site as i had the exactly the same problem as you have and did the following :
The speedo is basicly three parts . The head , the cable and the plastic drive in the gear box . What you do is first replace the plastic drive pinion [cheap] and see what happens , if still the same change the cable [?35.00] . Lastly you will then know its the head and thats the bad bit as VW want ?120.00 + for a new one .
Good luck, the Haynes manual shows how to replace the bits . My Golf had a faulty head and i was lucky to get a second hand one from Ebay but the price of these has rocketed and you can not guarantee they will work .
My 79 gti has a similar problem but a bit different.
The speedo arm wobbles about 3mph but it is out of synch with the spped I am actually travelling at. The speedo goes to 40mph when I am actually doing 30 but the gap seems to lessen as the speed increases.
Is it a case of doing what chudd has recommended and seeing what happens or has anyone got anyother ideas?
