Speakers for cabby
(In Topic #108079)
Speakers for cabby
~Madferret
Mk1 1457cc 5door GX '83
Life Member
I used Infinity 452i 6 x 4 105w in the front (straight fit)
and
Infinity 452i 4 x 4 in the rear.
Try Southside Audio, Southampton. I got mine from there about ?100 all in p+p I'm sure they'll have Infinity to fit 5"…. if you want to use that brand. That was in 2005 (I think).
I take it that your '90 does have door pods, if so there are 2 designs 1. a big round style and 2. an oval style if yours is the oval the there is a screw that holds the pod in place at the front. You then have to wriggle the pod about a bit to get it out. Unplug/ screw the old speaker and replace with the new. Replace.
The rears are more complicated (only a little). You have to remove the plastic seat belt cover at the base and then pop the rear card off its mounting. Once removed you will probably find a plastic membrane. Turn this back and locate the speaker. Unscrew and refit the new on . Replace card etc.
My rear speakers were wired from factory so that the balance couldn't be altered. There was a small block connector just below the knee bar on the A post. I chopped that out and replaced the rear cables with decent ones to get better sounds.
