Speaker cable
(In Topic #72672)
Speaker cable
1983 1100 C
1983 1100 C
I wouldn't recommend using really cheap cable though as the sound quality suffers, as the cheaper wires have a higher resistance.
Mike.
1983 White cabriolet GTi
1983 1100 C
1983 1100 C
It was only when I came to putting the wire through into the tailgate I suddenly found a bunch of other wires. Yep, you guessed it, it was already wired up to take it, just needed to be plugged in, and a relay and switch installed!! You've never heard such expletives!!
Morel to story, it's definitely worth checking if the wires you want are already there! Saves hours. Just felt I had to share that for some reason!
Grey for one side, Green for t'other.
Still using it in fact.
Peter.
1980 1600 GTI, daily driver.
Only problem was I had 4 grey/blue & 2 white/black ( which went to front)
So wired up 2 grey blue & no sound…… :dontknow:
The doughnut had only used the same wires as the dash lights
If Its Loud and Noisy , I'll take its picture
Thinking back my Golf CL did have 2 pairs of wires, one purple, one green. Just remembered that as i was reading the last post, so retract what I said above, it's fairly likely the wires might already be there, just need to do some digging around!
Life Member
1983 1100 C
1983 1100 C
Life Member
