sony stereo fitting
(In Topic #129862)
sony stereo fitting
Hi Guys/ gals im new to all this so not sure how it works. Just joined and looking for some help on how to wire this sony xr 6759 rds to my golf. It doesnt work by just fitting the iso's which is due to different wiring and a constant live reqquired by the unit? so will it work and how????? helllpppppp ????
neilson
You can wire any stereo in really as long as you have at least a constant live feed. As you can wire the constant live to the stereos live and switched live supplies.
However if you want the stereo to turn off with the car ignition then you will need to have a switched live feed via the ignition relay. Most cars will have both. Usually the live feed to the stereo will be red and the switch live will be blue. Not from the car side however!
The rest of the wiring will be for speakers and that will depend on how many you have plummbed in.
Its not the easiest job in the world, but if you know how to use a digital multimeter and have some time and patience its not too difficult to get it sorted.
06 Audi A3 (Wifes daily)
This might help;
http://www.installdr.com/Harnesses/VW-Wiring.pdf
You can get ISO connectors that you splice into the Golfs wiring making any further stereo replacment plug and play
