smoke out of dash HELP! pls
(In Topic #78794)
Golf c mk1 1100, Needs more power
Life Member
The headlamp switch smoking is a common problem and its best to change it to be on the safe side. I got mine form GSF and it was only about ?6.00 for some reason.
The bulb that illuminates the heater slider controls will cause your fuse to blow and smoke if it touches against the metal work of the dash. (I've done it so many times!!).
Change the switch, check your fuse and put some tape round the bulb holder to provide better 'grip' so it won't fall out again.
Dan
You'll be ok if the wire has not burnt through to an earth or another circuit. This had happened onmy Campaign before I had it. I ended up replacing the wire in the end.
Rich
Note that there is a junction of wires behind the instrument panel that the wiring diagrams show, but do not indicate where it is physically located. I included a photo in this brief writeup of the mess.
http://www.vwgolfmk1.o…=0&postorder=asc&start=10
I replaced the headlight switch and virtually every inch of the blue/grey wire as it was fried from the ashtray to the switch…..bleah. :?
Everything works now…..but scary stuff, you know?
