slow window wipers
(In Topic #122163)
slow window wipers
Website Manager
You can take them apart and clean them up and regrease them, this helps a lot, if the corrosion inside is really bad they can be hard to push through the housing though.
GPC use to do replacement spindles, not sure if they still do though.
They were never the fastest of wipers anyway. Another popular mod is to use a mk2 Golf motor, it hangs the opposite way so you have to do away with the third mount, if you go down this route make sure you get the mk2 plug as well with some wire still attached to splice into you existing loom or fit spade connectors to fit into your existing connector. The wiring colours should match.
G60
