Single headlight Question
(In Topic #138707)
Hey all
If you run a single headlight do you have sidelights wired in
if not how could i wire them in?
Ash
Ash
Clasic lambretta owner
1988 Subaru justy project
Nothing to do with whether its single or twin headlights. Golf Mk1s have a sidelight bulb in the headlamp (separate from the headlamp bulb) which has 2 connections to it, power and an earth. Additionally, some models have to comply with dim-dip regulations which means that with sidelights turned on and ignition on, the dipped beam bulb is powered at a lower voltage. This is done by a circuit of its own and a resistor element.
cheers for your help
