Sidelight
(In Topic #79334)
Sidelight
I'm having a problem with one of the sidelights on my 1992 cabby not working. I've established that I'm not getting power to the positive connection on the bulb holder, but it's not the fuse as the tail light on that side is working. This makes me think it's either the wire itself from the fuse panel to the light or the connection at the back of the fuse panel, so I'm planning to check the back of the panel and the contiuity of the wire from there to the light.
As I've never had the fuse panel out before has anyone got any top tips on getting to the back of it and, more importantly, getting it back together again? Also I'm working off the wiring diagram from the Haynes for a Mk2, anyone know if there are any significant differences from this?
Ian
'89 Clipper Auto and '92 GTI Cabby
Ian
I seem to have a bad connection on the wire from the back of the panel to the sidelight as the resistance is several kohms. I think it's at the multi pin connector that goes into the back of the fuse box. Anyone know how they come apart - does each metal connector just pull out of the plastic - and what's the best way to put them back together again?
Ian
