senders
senders
Hey
Ive got 3 VDO gauges from an audi cab. Oil Temp, Oil Pressure and battery voltage. I wanted to know if u can use oil temp senders or pressure senders from any audi engines? Only wanted to know coz it'll be so much easier for me to get any audi part than buy a part from anywhere else.
If anybody could help me, i'd be grateful
The senders will be stamped with the temp and pressure range. You need ones that match your gauages, ie a 0-5bar sender for a 0-5 bar gauge.
The pressure one will also be a 'top-hat' canisister one that also acts as the presure swtich for the clocks, as you will need one of the holes in the engine that one of the existing switches is using.
