S1 Electric problems! Indicators etc
(In Topic #132654)
Picking up a '79 Series 1 Golf L this weekend hopefully, trailering it back though!
Prior to a recent body work overhaul, it's been sat, the indicators, & hazards don't work.
I haven't had time to do any fault finding, but the fuses are A-ok apparently.
Is it a case of removing the hazard switch and cleaning terminals?
Would it be the flasher unit?
How would I go about cleaning/checking terminals etc on the indicator stalk?
Cheers,
Alex
1979 S1 MK1 Golf L FOR SALE! http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=101471
1970 VW Beetle 1600 Twin 34 ICT\'s - Betty
1973 Marathon Beetle - The Moll\'s
The question is, can you use a multimeter?
What should I be checking? I've done fault finding on my spaghetti style wiring in my Beetle, so i'm not a multimeter virgin!
I know this is a stupid question, but besides changing the relay, how else can I check it?
Cheers,
Alex
TwoToneAlex said
I have a multimeter, use it? I hope so
Cheers,
Alex
i think it will be the relay as both the indicators (which could be stalk) and hazzards(could be switch) but as both have gone id say relay, if it was one or the other i would still start on relay
If you can read this, thank a teacher,
If its in English, thank a soldier.
A soldier fights not because he hates whats in front of him, but because he loves whats behind him.
your best off just replacing the relay first unless you fancy cracking the haynes out with a multimeter?
Lee_dub said
well its not that simple as they both use the same wiring mate. the indicators are wired through the hazzard switch to the fusebox.
sorry mate, new to Golfs, but only going on military land rover etc, and basic electrical principals, ive got a haynes so if poster is stuck i can help, but its nothing compared to knowledge of the MK1 that you have, still bet a a good beer its the relay lol
I've bought a relay to test on Friday, besides that, is it a case of taking off the steering wheel, changing the indicator stalk, and then seeing?
Cheers,
Alex
you say the hazards work, then the relay is fine and you need to be looking at the wiring from the hazard switch and the stalks them selfs.
open your haynes and start doing continuity tests on the wires in question and checking for voltages where applicable. I don't have a haynes with me so I can't tell you what wires but if you look it will be obvious on the circuit diagram. Aside from that mate I can't help you any more
Much appreciated,
Al
Cheers,
Alex
