reverse lights
(In Topic #97778)
reverse lights
<a href="signatyar.jpg picture by orrinb - Photobucket"><img src="http://img.photobucket.com/albums/v725/orrinb/signatyar.jpg" border="0" alt="Photobucket"></a>
http://www.vwgolfmk1.o…rums&file=viewtopic&t=763
You'll need a new switch from GSF, but you'll need to move the wires around slightly on the wiring plug.
Cheers,
Gav
Mk1 Golf floor mats - for tin top and cabriolet - Zero7796 17298Five
Pete :wink:
Its not an MOT failiure so i never worried about it, must admit tho it somethimes got funny when trying to reverse in busy areas.. :mrgreen:
my fog light NEVER works, I got a mechanic to look at it last year as it needed it for the MOT and it worked for a week.
Any ideas?
reverse is the way forward
Peddersgolf said
This is switch for reversing lights on gearbox, 1st check your fuse, then bulbs etc, then buy one of these and should sort your problem out fella
Pete :wink:
Bit different to the GTI/MPG type one that is, I didn't think to ask stubager what model/engine he's got.
Check what type you've got stu before you buy one, either type are easy enough to swap.
Part number for switch is 020 945 415A, also ask for 2 pin incase yours is, part numbers 357 972 752 or 000 979 133
Pete :wink:
reverse lights
