Rev counter - which wire to the Digifant coil?
(In Topic #124409)
cheers guys,
Wil.
She needs PREMIUM DUDE, PREEEMIUMMMM, DUUUUDE!!!!
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
I have heard the ecu signal is compatible with the MK1/2 dash, so hopefully that will work. if not you can convert it to run a MK2 Coil + tci unit, then get the rev counter signal from the -ve side of the coil as per factory MK1/2
the pin on the mk1 fusebox depends which fusebox you have, early ceramic or late blade. but if you still have the old loom its where the red/black wire from the -ve side of the coil goes
