Relocate Power Roof Switch
(In Topic #136643)
I am thinking of installing 3 VDO gauges into the centre console of a 1993 GTi Convertible. The power roof switch currently sits in the position and after any advice on good alternative locations on the dash for the switch that has worked for any others and looks the part.
Cheers,
Del
Member of the month GET YOUR SAY IN NOW
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=86608&highlight=
what you coudl do though is move the switches to the doors using corrado switch holders mounted in the doorcard, or somewhere else that is convenient.
see here:
I was thinking of mounting it somewhere knee height on the dash and you've certainly given me an alternative idea I hadn't considered.
Cheers,
Del
Many moons ago I made a panel to do the opposite. I had 2 VDO gauges, out of a Calibra, where the ash tray goes and kept the window & roof switches where they were.
it routes a bit differently but it fits fine. i had a load of slack wire bundled up behind the console as i had my switches in there rather than the doors
I'm pleased with the result and the use of the space where two blank switches looked a little bare before. It also leaves an option of reversing it without having had to cut a hole in the dash.
