rear lights help needed asap
(In Topic #119886)
1) break lights dont work the switch is bringing on the reverse lights instead
if there is anybody in the fakenham/norwich area that could come and help me there will be beer food and cash for there time thank you simon
quick rub on the contacts with some emery and a bit of contact oil and it's been fine since.
Jon.
Also check the earth/connector block for corrosion.
~Madferret
Mk1 1457cc 5door GX '83
reverse light is controlled from a switch on the gearbox (about 4" away)
first check is as stated above.
after that it is very difficult to cross wire the plug on the lights or the actual light board. but well worth a check.
the lights earth in the boot (passenger side) check this earth is clean and free from scum undue the earthing point and clean all the contacts..
this is normally due to a faulty earth connection (hence you see fords driving round with indicators that act like brake lights and brake lights that act like indicators.
