rear fog light
(In Topic #87210)
rear fog light
My fog light dont work, checked the bulb and earth, there is also live feeds to fog switch, also what is the reason for 2 positions on switch.
any ideas welcome
thanx Mel
I had a similar problem last year for my MOT, it was the only thing it failed on the mechanic said there was feed to switch but nothing came on at the rear.
Dont know if this applies but on mine there was an extra fuse on top of the fuse box, had to get right under to see it pulled it out and it had blown. Changed that fuse and hey presto it worked.
Dont know if it will be same for you but I was ready to re-wire it until I found that. Hope it helps…
Cheers :dontknow:
The fuse it was. !!!!
Mel
fog light - fuse
So glad I could help, see it's easy when you know how. What year is your cab?
Jamie
