Rear fog light on cabriolet inactive ?????
(In Topic #146987)
Fuel pump I pressume?
usually fuse 5 realy position 2. Common problem failed and dirty connectors in the fuse box and the relay terminals.
So a good clean up.
Pressume this is a GTI car what year as there was a 5 pin relay that takes a signal from the coil also on later cabrio's.
Does the in tank lift pump work? as you have 2 on later GTI. One in the tank under the rear seat and another under the body. The in tank was added, because some cars when cornering etc ended up with fuel starvation.
Another prob is rust in the tank from the filler neck clogging the inlet strainer gauze on the pump causing it to fail. Also make sure the fuel filter is clean in the engine bay.
