rear brake lights always on?
(In Topic #118067)
there always on, engine on or off. ive only had a quick look as ive just pulled up at a mates, and were currently having a small tropical storm here.
pulled the yellow connector out the back of the fuse box, which turns them off to stop me battery going flat.
so any idea's of what to look at/ poke/ bang with a big hammer tommorow would be much greatly recived.
Rich
If at First you don't succeed, find a bigger hammer
Life Member
Life Member
so had a look this morning, as the rain had stopped, and the switch is the hydrolic one just off the master cylinder, don't know if its normal but i have 2 switches(1 each side) bridged together, and it appears 1 is stuck on, so removed lead to it and lights go out.
lights still work as the other one is still plugged in, so dose anyone know if i can leave it like it is, or if it has 2 for a reason?
cheers guys
Rich
Not sure why one of your spades is dead but prob best to get it sorted!
if you are worried you could mod your pedal box to accept a pedal switch, that'll save you having to open your brake system
