Radiator fan wiring
(In Topic #74126)
Radiator fan wiring
can I wire this up using just the 2 wires? if so, how should it go? :dontknow:
eg. Brown to connector position 1 and red/black to position 2 on the fan
or do I need a different fan?
I imagine it will still work though… :?
My Build Thread
Should I just put 2 wires to the battery and try the connectors? I should get 2 speeds then just wire up to one of them? probably the higher speed and see how that goes
(can you tell my electrical skills are minimal at the moment :wink: )
I would - just fuse the live, just incase!!!
When you wire it up, if you get the + and - terminals backwards on the fan connector, I think the fan will actually spin backwards, so before final wiring, just make sure it is spinning the right way!!!
My Build Thread
another part needed, I'll PM Crazy :wink:
