Problem with break light
I have problem with break light. When you press break pedal nothing happens. Whats the possible problem. Has anyone electrical scheme for Golf 1 JGLD?
Faulty Bulb , pedal switch faulty or wiring loom, check the 1st 2 and let me know.
~Madferret
Mk1 1457cc 5door GX '83
If it has a pressure switch on the master cylinder, jump the two wires and the lights should come on. If they do the switch is most likely bad or the connections are dirty.
Soloved. Pressure switch faild. Thx a lot
