Problem with understanding wiring diagram. Please help.
(In Topic #114792)
I'm new to car rebuiling and to everythng that goes with it. I've bought a Haynes manual (UK 726) but I have big problems in understanding the wiring. I'm sorry for bothering you but I really need to ask you some questions.
So. For example I take this Lilac/Black wire (3 from the left) that is conected to 14 pin connector that goes to the instrument panel. The manual says that that wire is conected to the 3 contact, so it is.
In the manual it says that this wire goes to E12. It means multi pin connector E contact 12 that is connected to the relay, right?
I have followed it, but the wire goes to B3 =(
And the same story with most of the wires. Can anybody please tell me what am I doing wrong? Thank you.
And I also didn't understand what those lines in the up mean (15, 30, 31)
p.s. The steering wheel is on he left side. And sorry for my English, hope you understood something =).
And there is another thing I can't understand. So the Letters with numbers on the top indicate relay wiring. But how come it is written F in the diargam when there is no F letter on relay. And it also shows some connections to H but there were no from the start.
Not sure I understand your question about the "F". The letters with a number at the top don't indicate relay wiring but rather the connections on the rear of the panel. Just as you showed the "B" connector there is an "F" connector (or sometimes they are just a single pin). The "F" does not have anything to do with the relays, but they are also shown within the top area with their connections also shown.
For example here. No "F".
Thank you very much!
